10kman
10kman's Avatar
06.02.2007, 04:46 PM
When you say "at least 2.8v" for cutoff, do you mean 2.8v is the highest it should be set at, and i can set it to say 2.5v safely, or that is the lowest it should be set, meaning if I set it at 3.0v it'd be better?
If I set it wrong, meaning higher than it should be, the pack will just not give me total runtime, but if I go too low, then I can damage the cells (right?)......
