MetalMan
MetalMan's Avatar
06.03.2007, 01:08 AM
Originally Posted by AAngel
MetalMan, if you are hardwired and are still having bad cogging problems, then it probably won't help enough. I'm using the 5.5mm connectors and they are rather substantial with a lot of surface area for contact. I don't think that the connectors are the problem.
I was actually thinking along the lines of the connectors I used to use, which are the 4mm ones that the MM comes with. Never have I used anything other than 3.5m or 4mm, so those are my only possible points of comparison.
