lutach
lutach's Avatar
06.03.2007, 08:54 AM
Mine was on sensitive as well. Also, I had it in soft start to protect fragile gear boxes, the cut off at 24 volts.
Originally Posted by Eccentric
What did you have your "current limiting" setting at? I have mine on the Option 2 (sensitive), though now I might go the the Option 1 (very sensitive).
The owners manual says that the warranty doesn't cover over current. So he might be on his own here.
You can get the sensor that will got up to 300amps and 50v for the Eagle Tree but it's $130.
