06.03.2007, 11:48 PM
Lol, it was worth a try right? ;)
Yeah, if defective, then I would definitely send it to Neu for testing. If nothing more than peace of mind...
About the temps: If you are doing a lot of standing starts, you have to remember the kinds of current you are pulling. This current at 4s or 5s is going to develop a LOT of power. It only stands to reason that you are going to heat it up. Ever feel a 75w light bulb? That's roughly about the same size, but much less power, at least a factor of 10. Granted, a light bulb isn't the most efficient thing, but you get the idea. For the sake of argument: if you are using 4s and pulling 150A, and the motor is 90% efficient, that's 216W the motor has to dissipate. Yikes.
Edit: Here's an idea: If you have a lot of 4s and 5s packs, run two 4s packs in series for 8s. :) Of course, you need an ESC capable of that, but it's only a matter of time. The rpms would be a bit high at 41k (assuming you do have the 1400kv motor), but ok if not doing lots of long top speed runs. Even then I think it would be fine - after all, these are high-end motors...
