Originally Posted by chilledoutuk
i would not use anything less than 8000mah lipos for that dual mamba setup.
I was not aware that you have problems using larger pinions which is a bummer as motors dont tend to really like going 63krpm without getting pretty hot.
Agree...I plan to use high quality lipos...but also they will be wired in parallel so there are some benefits in that regard.
As for the 63K...agree there too, but Castle rates theirs at 70K (or 75K I can't remember at the moment). Just because that power is there doesn't mean the motor will be turning at 63K the whole time---restraint my friend :027: ....besides the same thing happens (heating) if you use too large a pinion and too small a spur (plus improper gearing can also cause cogging).
