Finnster
KillaHurtz
Finnster's Avatar
06.06.2007, 03:47 PM
The Mtronks are nice enough controllers, i have one in my Rustler. Just they are not rated that high amp/volt wise (80A/12cells), and are not that programmable (not like a MM.) The MM is rated higher, easier to find/service and no more expensive. 12cells/80A does not add up (techically multiply ;) ) to a lot of wattage.
To get max speed out of it you can try a huge motor like above, or I've seen people that run high hv L motors wich can go fast, Just they run hot. I thought RCM Mike had an article where they put an 8L into an MT and broke 50 mph on 4S. I have doubts about doing that on 12 cells.
This is still a dragster, its not going to be that reliable for bashing. careful not to fry the motor/esc
