zeropointbug
Z-Pinch racer
zeropointbug's Avatar
06.07.2007, 12:37 AM
No, I have not recieved the caps or the Quark. They sent out a new Quark w/ Pro-BEC free of charge AND without me having to send in my piece of charcoal...
My gearing was 18/51 single speed tranny, it went very slow... but like you said, it doesn't matter a whole lot because these things look much better moving at speed. :027: I did have narrow nuetral band on too though, maybe that helps low speed creep?
What you said about finding the weak spot in equipment...so true. Seeing as we are still far within the rated specs of the Quark, they should easily be able to handle it. (maxx's, revo's) I can't even imagine what would happen to it if we DID run it at 125A continuous?! :002:
I am thinking I will put some 5mm plugs on the Quark and tap the input leads there with the cap bank, and solder two wires into the plug? what do you think?
