bdebde
That's All Folks!
bdebde's Avatar
06.07.2007, 12:40 AM
I manage to use the slipper for traction control in my HPI MT2 (no center diff, just the slipper). If I set the slipper per the manual, the slightest blip of the throttle will send it into backflips (Mamba Max 5700 on 3s). I have the slipper set to the point where the front end won't come up under full throttle unless I hit a bump. I do need to replace slipper pads every so often, not bad though.
