I have the slipper set to the point where the front end won't come up under full throttle unless I hit a bump. I do need to replace slipper pads every so often, not bad though.
I'm surprised that the pads on the slipper don't need to be changed more often with the slipper being that loose. Have you noticed how hot the slipper gets with it's adjusted like that?
