Thread: BL muggy!
AAngel
06.07.2007, 03:04 PM
The MGT has its problems too. I posted about those on the other MGT thread. The MGT also comes with those tiny 14mm hexes and I stripped out three sets of wheels with perfectly good tires on them. I added the 23mm hexes, but they are still driven by those tiny little pins and they do break. The MGT would, however, be easier to convert from a "tools needed" standpoint. I just used some 3/16" thick aluminum angle, when it had the tranny in it, to make the mount.
I think it's a toss up. Go with what you like. I think the Muggy is a better truck. I just like the MGT. I can pretty much fix anything that might break in about 10 minutes.
What I meant by flips off of trees and walls is that I can actually drive my MGT up a vertical wall or tree and it will do a backflip off of it. I can't do it as well as my son, but it's not too hard. It really freaks people out when they see that.
