Finnster
KillaHurtz
Finnster's Avatar
06.07.2007, 03:57 PM
Originally Posted by AAngel
OK, I don't remember. Have you ever built a brushless monster truck before? I'm just asking, because you seem to be very pre occupied with speed. Of course, most of us go through that stage, but it comes when you get to a point where you have gained some experience.
If this is your first conversion, I think that you should be looking for a solid setup that will turn on and roll when you want it too. I'd go with a MM and a 9XL. A nice conservative setup that will surprise you with its speed when geared right.
Hear hear, this is the way to go.
Its makes no sense either that you would build a truck "toned down to 50mph", and then drive in 1st most of the time. :032: You're likely to overheat the system as well if you undergear/over rev it. Build something solid first, then worry about landspeed records when you get more $ and the ability to use lipos.
