RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
07.12.2005, 10:22 PM
As I suspected, the steering turnbuckle is mounted on the upper portion of the steering knuckle. You likely have quite a bit of bumpsteer as well as the rubbing issue. Take the outer end of the turnbuckle and move it to the lower portion of the steering knuckle(screw up from the bottom, attaching the turnbuckle to the bottom of the knuckle). This should fix a couple problems at the same time (rubbing and bumpsteer).
