06.08.2007, 07:22 PM
using this conector gets you double voltage not runtime right. FOr example if you used this with a quark, and 2p2s 4000mah maxx amps would you have (1) a 8000mah 2s battery pack or (2) a 14.8volts going to the controller at 4000mah.
