Originally Posted by GorillaMaxx360
using this conector gets you double voltage not runtime right. FOr example if you used this with a quark, and 2p2s 4000mah maxx amps would you have (1) a 8000mah 2s battery pack or (2) a 14.8volts going to the controller at 4000mah.
If you used this parallel plug with a quark, and 2p2s 7.4V 4000mah maxx amps would you have: 7.4V with 8000mah
Batteries in parallel double current...not voltage.
Batteries in series double voltage...not current.
Brian has a good cheat sheet for this on his profile.
