06.09.2007, 01:58 PM
1 yes, no problem
2 yes, the receiver pack has nothing to do with the rest of the circuit; you can use any voltage on the setup you want
3 Yes, you just hook it up to the receiver. (some speedo's need to have the red wire removed)
4 You simple hook it up to a loose channel on the receiver.
5 Yeah. i used it on a savage, i used KAN1050 cells, but i also had a GP1100 pack.
