06.09.2007, 06:02 PM
The software that I am speaking of is for those who want to run the novak velociti motors for 1/10 scale. The fact that it is sensored isn't the problem. The fact that the motors are wye wound and have steel stators is what causes them not to run smoothly with the MM and its current software. The HV motors are basically the same as the velociti motors, but with longer cans, so I assume the new software will do the trick for them just as well.
Suicideneil, again HV4400 does not have 4400 kv. I still have no idea how novak came up with those numbers. I know for a fact that the HV6.5 is the exact same motor as the HV4400, but with a sintered rotor and a ribbed can, and I know that my ss5800 powered xxx4 did not go 55 mph with 7 cells, because that is how fast it would have gone if the kv was really 5800. Even my feigao 380c 9t, which is rated at 4400 kv, was a tad faster than the ss5800 geared the same.
