Originally Posted by AAngel
I'm unclear about something. First you say that the connectors that you got are smaller than the connectors on the MM, but you also said that you were running the setup and then you make reference to hardwiring.
How did you make the connections to get it running when you saw the cogging? A bad connection like a loose on or a bad solder joint will definitely introduce some pretty horrible cogging.
Sorry I wasn't clear.... I ordered the motor expecting a Wanderer (because that was the picture) so I ordered some of the 5.5 connectors. When I got the package it was a Feigao and a bunch of connectors but they are very small (I think 2.5mm). They came from Mike so I'm assuming they are quality just seemed a little small. So I hooked everything together using the new connectors I received removing the 4mm original on the MM. I know people mentioned hard wiring or using larger connectors that's why I'm thinking about hard-wiring the MM to motor. I also just changed the settings on the MM so I'll see how that goes.
