06.11.2007, 01:33 AM
Blipo, with the Neu motor that I got, the only instructions were about using mild timing settings; however, I did get on Neu's website and under the FAQ section, they do explain that you can gain some performance benefits by going to a medium timing setting with the Wye wind motors, but also explain that Delta wound motors do not see any performance benefits from increased (or should I say advanced) timing and recommend that only low timing be applied for the Delta wound motors.
The initial post at the start of this thread has me a bit worried. I'm going to assume that the statements made by Aveox are generalities which apply to Wye wound brushless motors. If they are, then which way does the motor need to be turning for it to run great and NOT suffer from poor performance.
I recently purchased a 1512 1.5Y which was supposed to be a 1900kv motor. When I wired it up, my impression was that the performance sucked. I don't know everything, but I do have enough experience to know what a 1900kv motor on 4S lipo should perform like in a truggy. I could only conclude that one of two things happened. Either the motor was defective, or it was mislabeled at the factory. Since these motors are hand wound, and therefor subject to human error; it could have been either. My reason for thinking that it was mislabeled was that it ran too good for something to be wrong with it. The more I geared it, the better it got. When I put 5S on it, it came to life, so I figured that I had gotten a 2Y (1400kv), rather than the 1.5Y that I was supposed to have gotten.
Now that I read this thread, I'm wondering if the motor was just turning the wrong way. I wonder how the way a Wye wound runs would be affected by running the motor with the Quark controller. The information provided by Aveox suggests that performance in either direction would be equal, if timing corrections were made when changing directions. The Quark employs an automatic timing technique which is supposed to set the timing to whatever is ideal.
My question now is...what direction does the motor need to turn in to realize its full potential?
BTW, I also got an email back from the vendor that I bought the motor from. He said that mine was the second this month that had to be sent back to Neu. The other had to be sent back due to the motor shaft sliding out of the endbell. I also have to add that I got Neu on the phone. They were very curteous and nice, but after having gotten off of the phone I realized that the person hadn't actually told me anything. It seemed like she was talking in circles. The emails were like that too. All I know is that they received my motor last Thursday. When I enquired by email, the answer that I got only confirmed that they got it, which I know already. The email did not say anything else.
On a positive note, I haven't heard of anyone complaining about the performance of either the Delta or Wye wound Neu motors. The added efficiency that you get with the Wye wound motors is supposed to be negligible.
I suppose I'll just have to wait and see, which absolutely sucks.
