06.11.2007, 04:17 PM
What motor is this again? I can't believe you didn't blow up the MM on 18 cells. The caps are only rated to 25V, so I wouldn't push my luck w/ it. Fully charged good cells could pass this..
Did you check the original connections w/ a voltmeter? 25 is awfully slow for a BL. No other probs?
