06.12.2007, 09:03 PM
To shift, you need a 3-channel radio, which is what the TQ3 is. However, you probably won't ever use first gear unless you want some finer low speed control.
Some people have problems with glitching, some don't. You'll just have to see. Just keep the receiver, antenna, and low signal wires (throttle) as far away as you can from any high current wires (power and motor wires).
