06.13.2007, 08:57 PM
The 4600. Motor temps were ok, but the ESC was quite warm, which means overgeared. And I'd like to run the larger 2.2" wheels so that will just heat it up more. The track I was running on requires a lot of quick acceleration because it is kinda tight with jumps right after turns. So, I'm thinking an L size motor would be better for the added torque. I wish Mike has more options for those Lehner basics. I was thinking about using a 1920, but will probably have the same issue as I do with the current setup.
