othello
HV basher
06.17.2007, 03:16 AM
@nativepaul
The video you are referring to does not show the performance of my actual setup therefore i didn't posted it here since i considered it offtopic. At this time i was using 1 year old gp3700s, a Genius 70 controller which was only capable of 700 Watts and an Graupner 600m 8 pole Motor.
This is a screenshot from the video
And here are the links to the video
medium resolution: http://www.braintrust.at/2007/ds/cro...deo_medium.mpg
high resolution:
http://www.braintrust.at/2007/ds/cro...ideo_large.wmv
@AAngel
You're right about my mah consumption. It's high. But i would not blame the motor for it, since i got similar readings with my 8 pole Graupner 600M. It mostly has something to do with the challenging sort of racetrack where i drive. The rather high wheight of my setup. The relative high KV motor. And of course my driving style. The tires i have mounted have a good bite even on dirt and are rather big for buggy tires. All that together sums up to 450mAh per minute on a dirt surface when pushing things to the limit.
On my maiden drive i only had 150mah per minute. Tyres had no grip. Differentials where not setup properly so all the motor power unloaded to the front tyres. At this time i only had Amp peaks of 50 Amp. As i tuned my setup Amps went higher and higher. My Actual setup can draw up to 120 Amps which is the limit of my batts and esc.
