Originally Posted by AAngel
andreazinno,
I see that it took about one month for you to receive your motor. Of coure, you are in Europe, so delivery would be faster to you. I would just like it ask if the one month wait that you experienced was due to your special order of the 5mm shaft. Do you know how long the wait would have been for you if you had just ordered a motor with a 4mm shaft?
Considering that the Neu motors require relatively expensive controllers, the Lehner motors seem like the best choice for a good motor.
Hi Angel, the problem is that Lehner builds the motor just on-demand. When You put the order to the Hydro&Marine, they send the order (whatever it is for a "stock" motor or modified by special request, like the mine for a 5mm axle) the first friday after the order date, then Lehner took two weeks to built the motor and the, finally, the motor will be shipped.
Bye
