metalry101
06.17.2007, 04:28 AM
Hey guys...sorry this guy was a tool and wouldn't listen, but I do listen, so how about a little advice on the same topic?
I have an E-Zilla...I'd like it to be faster...a lot faster. 12 cells...maybe 4S Lipo eventually, but for now, plan on 12 high end NIMH's because it's what I have. I've heard the MM ESC will be plenty for this application, so given that the MM will work, all I really need is a motor suggestion.
I already have an HV 6.5 powered E-Maxx, and it's plenty powerful for me. I wish it was about 5 or 10 mph faster on the top end, but I have no complaints about torque at all. Most people on here seem to think the Novak systems are garbage (and it is in some ways), yet I'm happy with the performance of mine, so obviously I'm not too hard to please.
One thing that is semi-different about me is that I have about 10 trucks that I run on a regular basis...so this won't be seeing 15 battery packs a week..or even 5 a week...but when it does get taken out, I'll run it until I run out of daylight, until it's broken in half, or until I run out of batteries. When it gets taken out, it will be run HARD, probably battery after battery after battery.
So...what would you guys suggest given the criteria?
-Reasonably priced.
-Works well w/ the MM (though if it won't work, I'm open to other speed control suggestions)
-At least 35 mph on 12 cells, but not necessarily more. I'd rather do 35 for 15 minutes than 45+ for 7 minutes.
-Good enough power to throw it around a bit, but nothing ridiculous. This is a smallish, fairly light truck after all.
-Ideally...1/8 shaft, but I know that's pushing my luck.
-All of this on 12 high end NIMH's.
  Send a message via Yahoo to metalry101 Send a message via AIM to metalry101
