skellyo
skellyo's Avatar
06.17.2007, 10:16 AM
Originally Posted by Dafni
Could somebody please post the part number of Proline wheels that would fit this truck and take on regular 2.2 truck tires? (hex or pin does not matter)
Thank you!
Daf
Any RPM or Pro-Line wheels that will fit the front or rear of an electric Rustler/Stampede should work on it since they're 12mm hexes. Any Pro-Line wheels that fit a T3 or T4 with 3/16" axles will fit if you use a shorter drive pin. Here's some options:
For Hexes:
http://www2.towerhobbies.com/cgi-bin...?&I=LXDNC4&P=7
http://www2.towerhobbies.com/cgi-bin...?&I=LXDNC5&P=7
http://www2.towerhobbies.com/cgi-bin...?&I=LXMV44&P=7
http://www2.towerhobbies.com/cgi-bin...?&I=LXMV46&P=7
For Drive Pins:
http://www2.towerhobbies.com/cgi-bin...?&I=LXFDX1&P=7
http://www2.towerhobbies.com/cgi-bin...?&I=LXDW25&P=7
http://www2.towerhobbies.com/cgi-bin...?&I=LX2986&P=7
The difference between the front and rear versions of the RPM wheels will be how far offset they are.
