Originally Posted by BrianG
You are probably ok with not balancing everytime, but why not do it? It's not going to hurt anything and you can be sure that your pack will always be balanced. I balance while charging all the time. Any decrease in charge time by not using a balancer is negligible. Technically, since the bal does discharge at a low rate, charge time does increase, but is so small that it really is not worth mentioning IMO.
I agree with you & i feel safer using the balancer evertime.
