06.25.2007, 09:41 PM
Spektrum is pretty resilient with noise because it is such a high frequency compared to the servo digital frequency. You can literally hear the servo, so it's probably in the audio frequency range (20Hz-20kHz), which is WAYYY below 2.4GHz, even counting harmonics. :) If you are worried about it, you could use an aluminum or carbon fiber plate between the two to help shield the radio.
