brijar
Knowing You're Hooked on RC: Priceless...
brijar's Avatar
06.26.2007, 04:04 PM
Well, I would really rather solder the cells instead of using the spot welded bus bars that they come stock with. I know almost all battery companies advise against soldering their batteries, but NiMH's solder just fine, if you are quick. I have an 80 watt Weller iron, will that be quick enough to not heat up the A123's too bad, or is there other concerns I should be worried about when soldering?
Thanx,
Brijar!!!
REVO 3.3 Conversion: 3906 trans, CC 1518, MMM, 6s Gens Ace 5k 40C, LST Diffs, Summit shafts
Slash 2x4 LCG
Two Slash 4x4s
Rustler
