06.27.2007, 09:35 AM
I've never had trouble with the score-and-break method. I score each side twice to make sure the score is deep enough, put the excess piece over a flat corner, clamp it down, and snap it off. Every once in a while, there might be an imperfection that I'll touch up with a dremel, but I'm kinda anal about having straight edges and perfectly rounded corners...
@Wallot: Can lexan scissors cut thicker stuff, like 1/8" +?? Are you thinking body lexan scissors?
