Originally Posted by Serum
4 in large lines; the lower the KV of the motor (from the same series) if they are wind at the same method (delta or wye) the lower KV will have more torque and can be geared taller. the 7700 can be geared lower with about the same poweroutput at the wheels.
So would you say as long as the gear ratio can be achieved for a low KV motor to match the high KV, there should be no need for the high KV motor even on a low voltage? The reason for the constant voltage issue is that I race 1/10th and voltage cannot be upped. Does a higher turn motor have higher resistance or am I off base there?
This confuses me only because I have tried to match MM5700s with my MM4600 on 2s lipo in my T4 by gearing up as I wasn't allowed more voltage. I could get the same top speed but the 4600 got hot quicker than my friends 5700s and seemed more sluggish. We were all running TP8000 2s lipos. This is why I assumed it was having trouble accepting the current the extra gearing was asking for due to resistance. I will say though that it was a one time experiment and I bought a 5700 shortly after for that large track. There may have been something else going on with my setup.
Thanks a lot for the info.:dft009:
