Finnster
KillaHurtz
Finnster's Avatar
06.27.2007, 05:04 PM
Originally Posted by t-maxxracer32
what do you use to measure the voltage count? id really like to get me one of those.
thanks!
That would be a voltmeter, available at most home supply stores (home depot), Ratshack, hell even pep boys for cheap ones. :027:
I was basically doing the same thing last night. I took my pack apart and prepped the cells. Stupid thing tho is I was easing the cells out of the casing, when all of a sudden it just went and all the cells crashed to the floor looknig a like a string of sausages. Worse yet its there was a little spark. :o One end has a little scorch mark, but for the life of me I can't find what bit it shorted against. My batt luck has been a bit down lately, despite the extra care I've given.
However, its not too bad. So I'll just see. I tested every cell, every one was 3.301V, so I would say currently well balanced. I'm not sure if i will add balance taps. I prolly should/will, but many others have stopped balancing as it seems they tend to self balance.
I made two cuts in the tabs to create a 5S pack and a 2S and 3S. I shooglued them together (like making nimh SxS), and tonite I'll solder a bit hopefully. I'm going to offset the packs to minimize the width. Looks like final width will be just over 50mm, about same width as TrueRc lipos, so should fit in my batt tray w/o mods.
(Poorly) Illustrated:
-ooooo+
.-ooooo +
versus as packaged in 10S
ooooo-
ooooo+
