Thread: My ERT thread
rchippie
rchippie's Avatar
06.27.2007, 08:01 PM
Originally Posted by MacII
It very much depends on the track conditions but I like it a bit stiff. Most of the tracks I run on are not very bumpy (at least not at the start of the day) the trend up here is big, flat base with nice size jumps, not bumps...so I run 50 or even 60 wt oil in the front and rear. I tend to run the same on both ends. I feel like the Electric truck has plenty of squat already so on mine, I don't drop the rear 10wt like you do on most trucks. As for Diff oils, it's 7K or 5K up front and 3K or 1K in the rear. In the center I mix it up often. I keep a 50K built and a 30K built. I like the feel of the higher oils in the center but I have swapped it down to as low as 10K. I like the 30K best though at the Wolcott race I ran 50 for instant acceleration over the triple.
DM
Thank's david
So you run 30 or 50 thousand in center, mine has 7000 in it i belive, from the guy who built it. I'll go up to at least 20,000 to start. My home track is very smooth ( well groomed) & a real blue groove track.
REAL MEN RUN BRUSHLESS
