08.25.2007, 12:11 AM
The MGM and Quark both have there weakness. The Quark can't run 6s even though it says it can, and it has overheating problems. But if you don't run 6s or plan to, it is a great choice if you can do the heat mod. I'll try to find the link for how to do it.
The MGM seems to have reverse/braking problems from what I hear. However if you don't use reverse or have it programmed, then it doesn't matter.
Which Neu are you talking about specifically? The one you have written in your signature would run great in an E-Maxx. I can't help with the gear meshing part as I don't have an e-maxx. Hope the previous info helped though.
