zeropointbug
Z-Pinch racer
zeropointbug's Avatar
08.25.2007, 05:11 PM
Yes, if you can adjust the current on the fly, then crank the amps to start off, then once it hits 3.6v/cell, then just turn it to 1 amp... that seems like the easiest to me.
Brain, nice to hear you would like to try them... totally, they need to be prismatic cells for them to work with all setups. They also need different sized cells, like some 4Ah, 6Ah, or whatever makes the most sense for the most used capacities.
