Originally Posted by zeropointbug
This is the stock Revo 3.3 chassis we're talking here, there is no batt tray.
Also, I have to fit that 'monster' Monster 125B (Avatar) somewhere too, maybe on a mount on top of shocks like you said?
Do you know how much room there is between the revo tranny and the body as far as width on the right side? I basically have the whole right side to work with here, so either two seperate 7s packs on each side (not my favorite idea), or one whole 7s2p brick on the right side.
That fact that it's an 'odd' 7s pack makes it more difficult, IMO.
Well no, but I assume you are going to make one, yes? :p Your intended layout will determine the design. That's what I mean
Between the center tranny "bell" of the chassis and a stock body is ~50-55mm. My tray is ~48mm +1/4". The body touches, but is not pushed out. I put a side guard on to protect/secure lipos. With A123s you could cut this out. You could angle the tray down if needed to get some space. Really you are going measure the chassis out w/ your batts to see how it can fit together. I curious to how you going to build the pack, as a 7S is an odd #. A double shotgun pack may be nice and low cg, but will be tricky to fit.
