08.27.2007, 10:01 AM
I also heard that you put some Jato pins like these: http://www.buytraxxas.com/product_in...oducts_id=2399 into your center tranny. Can you explain to me where these pin(s) go and are they actually needed?
Those pins replace the ones currently in the tranny. There are two places where these go; on the input gears (blue ones in the pic in the first post), and on the output gear that is on the output shaft. These pins secure the gear to the shaft.
The Picco is a strong motor, but doesn't have that instaneous snap that BL has, which can break these pins.
