Thread: set up help
08.27.2007, 04:14 PM
Well, running high voltage on a low kv motor will help reduce the current. Reduction in current will help you pick batteries that aren't so fussy. For the same speed and power in a lower voltage setup, you need more current. It's the high current that makes the lipos expensive.
