Thread: Planning E-Revo
Pliska
08.28.2007, 08:28 PM
Hey
I didnt think of useing Sheet Metal, My dad works with it all the time so i can get some for free(hes an Hvac tech), Thanks for the tip!
As for gearing i was thinking about useing 36t mod1 spur and a 20t Pinion, according to the speed calculator it should put me at around 40mph, does this look good?:
Differential Ratio: 2.8461538461538462
Transmission Ratio: 2.2941176470588233
Other Ratio: 1
Spur Tooth Count: 36
Pinion Tooth Count: 20
Total Voltage: 14.8
Motor KV: 2084
Tire Diameter (inches): 5.75
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0.0073
Spur/Pinion Ratio: 1.8 : 1
Total Ratio: 11.75294 : 1
Tire Circumference (inches): 18.06 inches (458.83mm)
Total Motor Speed: 30843.2 RPM
Vehicle Speed: 44.89 MPH (72.11km/h)
Effective Speed Rate: 3.03mph/V (4.87kmh/V)
Effective KV Value: 2084
