08.29.2007, 04:38 PM
It was 3s, and i moved the trim both ways an equal distance, before it moved. The throttle trim is centered and has been reprogrammed to the center. When i moved the trim, If you are right, it should have dropped towards zero before going back up either way. It never dropped till the motor moved
SpeedyBL, No i did not remove the servo from the equation
