cemetery gates
08.29.2007, 06:28 PM
Originally Posted by VintageMA View Post
cemetery gates - what gearing are you using with the 10L and what brand is the motor? I've noticed the Feiago motors will tend to pull higher power spikes than the LMT/Neu's with the stronger magnets.
It is a feigao 10L geared 20/46 (tops out at 39, radared). In my revo with a neu 1515 1y on 4s and I get many 120+ amp spikes. In your case you are running 6s with a lower kv motor so, you will pull less amps...
Bye
