Thread: 5mm gears?
08.29.2007, 09:48 PM
Ok what motor do you want to run? A 8-9-10 l leigao would be fine in a pede. I have a 12s which is 3000kv or so and run 15/54 gearing in it on 3s lipo. No problems at all, tems are acceptable, and run time is around 40-45mins bashing on a 4000mah 3s lipo. My truck is mostly stock, so it is light, a heavier truck would be ok since you would be using a l motor. I would say use a 3000 kv motor, 8l, and 14-16/58 gearing, on 3s lipo and it will be a hoot.
