Thread: mini question
08.29.2007, 11:13 PM
In general a motor will draw less amps as the voltage is increased. However the 6800 motor is spinning real fast on 2s and wizzing round at 3s. Problem with the mamba motors is that the are a 130s motor and lack torque. I eventually replace all of them with 280l or xl motors running 3s and just geared the vehicle to run faster. The motor/esc/battery ran cooler and I got longer runtimes from the same battery size. The lower kv higher voltage systems are more effecient and more fun too. The mini t is very light so it will be ok with that motor. I had a 5400 on 8 numh and then 3s lipo and it screamed, totally uncontrollable, but very fun. I would say a good 15c lipo in the 1100 to 1800 range will work fine in the mini t. The max amps 1100 will fit in the battery tray, it is almost square.
