08.30.2007, 10:53 PM
I can fit a 52 tooth mod 1 gear and a 16 tooth pinion with the align 600xl. It is 43 mm across. That is the lowest gearing that will fit. Also one side of the tranny will allow the motor to get a little closer than the other, just can't remember which side. I checked at the lhs today, a MGT 52 tooth spur is a direct fit on a stock emaxx slipper. Same internal size hole for the bushing and the pegs look to be the same size as well. Maybe put the complete 12 pegs in and tighten it up good to keep the heat down. I have been using a modified mgt 52 spur on my revo slipper conversion. I had to enlarge the ctr hole to fit the 5x11 bearing and drill out 3 of the peg holes to fit the slipper hub mount bosses. I really like mod1 gears, much stronger and quiter than 32 pitch.
