Superbasher
Superbasher's Avatar
08.31.2007, 11:44 AM
Differential Ratio: 1
Transmission Ratio: 2.6
Other Ratio: 1
Spur Tooth Count: 87
Pinion Tooth Count: 17
Total Voltage: 12
Motor KV: 5700
Tire Diameter (inches): 4
Tire Ballooning (inches): 0.25
Motor Current Draw: 0
Motor coil Ω: 0
Spur/Pinion Ratio: 5.12 : 1
Total Ratio: 13.30588 : 1
Tire Circumference (inches): 14.14 inches (359.08mm)
Total Motor Speed: 68400 RPM
Vehicle Speed: 68.82 MPH (110.55km/h)
Effective Speed Rate: 5.73mph/V (9.21kmh/V)
Effective KV Value: 5700
Motor Torque: Amperage not specified...
Final Torque: Amperage not specified...
The amps and ohms etc i'm not 100% sure on so i didn't include them.
  Send a message via MSN to Superbasher
