nativepaul
nativepaul's Avatar
09.01.2007, 02:17 PM
Thanks very much for taking the time to knock that up for me Brian, it is as I suspected from your 2x 3s diagram, just remove the red wire and plug the blacks into the next slots but I wanted to be sure.
I use bullet connectors so I will be plugging the cells directly into each other to series them rather than using a main power harness and ziptieing them to the balancer harness, electrically this seems to be the same can you see any problems doing it this way (assuming I mark the balance plugs so they go into the right pack)?
Xray XT8, 1518, MMM, 4s5Ah.
Lots of boats.
fastelectrics.net
