tonka truck
tonka truck's Avatar
07.21.2005, 07:05 PM
@ Metal man
For the charger priced $39, it is under chargers tab on the maxamps website. It is a 1-4 cell charger with a charge current of 500mah, V cutoff at 4.2v.
@ major azzwoopin, I would check about your idea of 6s with
different voltage packs.
Does anyone know about this? combining different voltage packs 7.4v and 11.1v packs. As I understand it as long as they are all the same capcity in parallel it does not matter about their voltage rating when in series
For instance you can combine a 11.1 v and 7.4v in series to make a 18.5v pack as long as they are each 3200mah?
"when fate shuts the door, climb in through the window" - anonymous
