Chapito
09.02.2007, 10:36 AM
I'm sure the muggy would make an awesome handling conversion. I have an 8ight-T that works great and the Muggy, as far as the layout, is very similar. I would highly recomend that you stay away from fine design. I have personal experience with sending a bad motor back that took out the speed control, which was'nt replaced the first time and then being sent a marine speed control in it's place(which is useless for cars) after waiting for almost three weeks as well as a suspect battery pack. I ended up selling motor, speed control, and mounts for a fraction of what I paid for them just to not have to deal with Chris anymore. Also, you are stuck using fd "bell pinions" if you use his motor mounts and imo they are junk as well. I'm not sure if Mike(RC Monster) sells a stock motor mount that will fit the muggy but if not he may be able to fab one up for you at a resonable cost. It is much better to locate the motor in the right, rear(stock batt. box location) so that yopu have all the room on the left side for mounting batteries and speed control. Good luck with whatever you decide.
