lutach
lutach's Avatar
09.03.2007, 05:44 PM
lutach, just wondering what kind of software your 200a esc will be running. Will it be good for all the different types of motors? Also, will it have standard programming options, reverse, etc? I am guessing that you have a company that already makes a popular esc and will be using their software and just updating the power output portion of the esc. Answer what you can without giving too much away!!!
They have a lot of great ESC already, but it was only meant for air. I tested a 100A 10S controller from them and it has the best start up I've seen and I used it with the Hacker ION-X motor, the 3688 motor and the Align 600L. All I can tell you is what I asked them to do. It will have features for battery type, cut off, cut off type, Timing, Brake strength, forward/brake/reverse or forward/brake only. You can use up to 15S lipos, but they said to keep it at 14S. One thing I was told by the engineer was that they would make a program card or box to go with the controller to make things easier to program. I can't tell you guys how much I stressed them on how good the brake has to be. So I will test one unit and when I give them the OK, they will make the rest.
