Originally Posted by suicideneil
Theres no way a sensored system should glitch like that, unless there is serious radio interference- what radio are you using?
........ just bear in mind your tire diameter if it is larger than stock, and the weight of the truck rtr (stock emaxx is 9lbs I think).
I've tried both my Spektrum System and the stocker Traxxas radio/recievers. Same exact result.
Tire dia is slightly smaller than stock - using pro-line's.
Weight should be right at or a little less than Emaxx.
I'm hoping its the gears.
