09.04.2007, 05:19 PM
The slipperential is ment more for helping to balance the power to the front & rear of the truck whilst racing, rather than helping to prevent wheelies (though it does use a revo spec slipper). If you can find one, I would recommend finding strobe slipper (dont go with the RR one, seems to be a bit poop by all accounts) if you can, if not then there is an alternative.... takea revo input shaft, trim it down in length, and then install it inplace of the shortend emaxx input shaft- now you have a revo spec slipper on a maxx. I would also say try changing the settings on your quark, maybe softer starting power & timing? maybe? Also, what voltage are your lipo cells (seem good ones by the numbers)- total of 4s Im guessing.
